what's the meaning
Old   April 30, 2005, 13:03
Default what's the meaning
arwang
> Reading "D:\BUBBLE.GRD"...
Building...
grid, Error: Null Domain Pointer
Error Object: ()
I use the fluent6.2,i cann't go ahead.
Old   May 1, 2005, 23:17
Default Re: what's the meaning
zxaar
it seems to me that the file u r reaidng is old format file and probably needed to be converted to new format of fluent6.
Old   May 2, 2005, 01:58
Harish
Make sure the solver option is set to fluent 5/6 in gambit.
-H
Old   May 3, 2005, 04:13
swarup
This is FLUENT 4 Grid file. you must have selected FLUENT 4 while assigning boundary zones to your geometry in GAMBIT.
Are you following Fil-->Read--->Case option? you may get this error in that case.
You should follow the path File-->Import-->Fluent 4
Old   May 3, 2005, 08:34
arwang
3ks,it's ok following your advice.
Physical meaning of pressure in pressure eqn dontknow Main CFD Forum 2 August 30, 2010 11:12
What's meaning of UDF FUNCTION zhaoxinyu Fluent UDF and Scheme Programming 0 March 31, 2010 09:04
what is the meaning of patching shyam FLUENT 1 July 29, 2008 07:25
want to know meaning Sangamesh Siemens 0 May 15, 2007 06:15
What's the meaning of "combustion scalar"and.... cfdbeginner CFX 0 November 27, 2003 10:02
