PROBLEM with Fluent 6.2
Old   April 29, 2005, 12:02
Default PROBLEM with Fluent 6.2
Luca
Hi everybody! I have a problem with UDF execute-on-demand calling. I want to run a execute-on-demand from a journal file. I try to set all from the TUI but here's the problem: the name of my UDF (for example nameUDF) has been changed to nameUDF::name_OF_MY_COMPILED_LIBRARY. So if I type: define user-defines execute-on-demand "nameUDF" my udf seems not to be present.Has anybody a solution? Luca
Old   April 29, 2005, 12:08
Default Re: PROBLEM with Fluent 6.2
thomas
here is what you could do: First load your define on demand via the fluent GUI. Then when it is done type in the TUI define>execute on demand .... there fluent is gonna give you the following message Execute on demand function name ["bal bla bla"]: ... The "bla bla bla " is the name you have to put in your journal file. Also make sure you libudf in the same folder as you fluent file. Ciao !
Old   April 29, 2005, 12:12
Luca
Ciao Thomas, yes Ok...but the question is: do you confirm me that the name of my UDF is changed? That means tha my journal file is not universal...I mean everytime I create a compiled library with a differetn name I have to modify my journal file???Luca
Old   April 29, 2005, 13:45
thomas
Well when you get:
What is the name between [" ... "] ?
Old   April 30, 2005, 05:27
Luca
the first is ["none"] then ["nameUDF::name_compiled_library"]. Luca
fluent convergence problem josip76 FLUENT 0 May 26, 2011 21:08
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 14:31
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 11:49
