Exporting problem from parallel solvers
Old   April 29, 2005, 09:49
Default Exporting problem from parallel solvers
Kong
File Export pannel reads a lot of file types to be exported from a serial solver, but a few of types only appear on parallel FLUENT. Just two file types, EnSight Case Gold and Fieldview Unstructured on the File Type in Export pannel activated only. Fluent version is 6.1 or 6.2. What a problem!
Kong
Old   April 29, 2005, 10:43
Default Re: Exporting problem from parallel solvers
Jason
Save your case and data, close fluent and run a serial solver of fluent. I use "fluent 3d -post" a lot... I've had better luck with it not "freaking out" but my machine is relatively old and slow. Open the case and data back up, and then you should be able to export the data as you want.
Hope this helps, Jason
Old   April 29, 2005, 11:11
Kong
But I should get the files at each time steps automatically on runnung parallel solvers of fluent to save time.
Kong
Old   April 29, 2005, 12:15
Luca
Unfortunately you can't. I do that by a UDF. I write to file for each node process data I need. Luca
Old   April 29, 2005, 18:56
zxaar
there is one more way of doing it, write the cas and data each time step, and then run journal to export each stage required data,
Old   April 30, 2005, 05:29
Luca
Yes zxaar you're right. You can also export a profile file each iteration. That works in the parallel case too. Luca
Old   May 4, 2005, 12:55
kamarul
yup, it should works fine in parallel solver. If you are running it through batch file, use "autosave" command to save case dan dat files at a time step interval (say at each 25 time steps).
It this what you're asking?
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 11:26
A Strange Problem in making Parallel (Ansys/CFX 12) a.sarami CFX 13 October 7, 2010 02:33
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 05:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 18:18
Problem using parallel Fluent Gustavo FLUENT 0 June 28, 2004 00:12
