kill-fluent warning
Old   April 27, 2005, 16:36
Default kill-fluent warning
gh
hello there,
i'm running fluent on windows 2000. it keeps crashing (particularly when i display images) and then leaves an icon on the desktop called 'kill fluent'. does anyone know what this is? do i have to run this programme???
thank you in advance, gh.
Old   May 1, 2005, 15:43
Default Re: kill-fluent warning
pUl|
The kill script is typically created in the Beta versions of Fluent in Windows. In *nix systems it is a fairly common routine and it is created in ~/ for each instance of Fluent that is started.
Executing the kill-fluent-pid script will cause the fluent process associated with the script to be killed instantly and following that, the kill script file will be deleted as well.
No, you do not need to run this "programme". You can safely delete it if you want to. Please check your display adapter driver and see if you can get around the problem by tweaking the hardware acceleration setting for video.
Old   May 2, 2005, 11:01
Gary Holland
thanks very much, i'll give that a try. gary.
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 17:50
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Community Contributions 1 August 27, 2010 06:15
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
[OpenFOAM] Could you please help me liugx212 ParaView 4 December 22, 2005 17:55
