animate
Old   April 27, 2005, 05:14
Default animate
joris
hey,
i am using a dynamic mesh with an UDF. if a turn off dynamic meshing, the animation and iteration work fine. the mesh motion preview is also ok. i try to plot the velocity profile at the end of the tube over time.
but if i turn dynamic meshing on, the animation does no longer work and i get the following error:
Warning: surface-integrate: empty surfacecx-xy-plot-data: unequal length argument lists
do you know what's wrong? thank you,
joris
How to animate the air flow patters inside a cylinder Vijay FLUENT 3 December 29, 2009 12:47
animate function trouble Willem FLUENT 0 February 12, 2008 16:24
HELP! Problem on Animate Benz Wolf FLUENT 0 May 26, 2004 05:03
animate on plane hakkż FLUENT 2 August 25, 2003 14:58
can I animate the dynamic simulation for process Jason FLUENT 2 August 20, 2003 09:37
