gambit installation
Old   April 27, 2005, 00:48
Default gambit installation
baskar
sir i installed gambit in my system. when i entered gambit, the gambit window opens and vanishes immediatly showing some error message. actually i couldnt read the error message. what will be the cause. anybody can help me thanks in advance with reg baskar
Old   April 27, 2005, 01:27
Default Re: gambit installation
Harish
run cmd and in cmd type gambit You might need to set environment probably.
- h
Old   April 27, 2005, 08:49
Mehdi Ghoddosy
Dear Baskar: Try this on command prompt (run in start menu): c:\fluent.inc\ntbin\ntx86\gambit.exe [filename] sample c:\fluent.inc\ntbin\ntx86\gambit.exe newfile
Old   April 27, 2005, 15:44
Gary
the same thing happened to me. for the first few times as soon as the error message came up i tried restarting gambit. however, my machine takes about a full minute for gambit to open up so maybe try closing the error window and then just leaving the computer alone for 2-3 minutes. it worked for me.
Old   April 29, 2005, 18:14
Chris
The way to open gambit, at least on a windows based machine anyway, is to click on the gambit.exe file in c:\fluent.inc\ntbin\ntx86\ folder as suggested.
As far as I know it is because Gambit is run from a dos prompt hence the need for Exceed.
This is the way I use Gambit. In fact if you create a shortcut to this file on your desktop or in the start menu this will also work.
Good luck Chris
Old   April 29, 2005, 20:25
zxaar
remove the .lok file (probably the defaul.lok) from the folder where gambit starts
Old   April 30, 2005, 22:00
Rajesh G
you can search for default_id.lok
Remove that from your system. Then tyr openig Gambit
Old   April 30, 2005, 22:02
Rajesh G
You can search for the default_id.lok. Then remove that file from ur system. .. and try opening gambit
Old   May 1, 2005, 15:48
pUl|
Wierd! If Fluent really wishes to support Windows, it should put in extra effort to code gambit in VC++ and avoid all this X-Server emulation stuff or else simply accept that *nix systems are way better and support them properly. Learning to work with *nix systems is NOT a nightmare. The X window System these days when used with a nice DE such as GNOME can make life a lot more comfortable.
Lazy, that's what they are :X
[GAMBIT] Gambit Installation Serious Problem,,,,, devesh.baghel ANSYS Meshing & Geometry 2 February 22, 2010 08:29
Gambit installation problem Panos FLUENT 4 March 5, 2009 23:44
Installation of gambit Sangeeta FLUENT 4 December 10, 2008 04:40
Gambit installation under linux Alex Main CFD Forum 1 December 4, 2008 02:32
Fluent and gambit installation into Linux Rashid FLUENT 0 January 17, 2008 02:43
