set boundary condition in Neutral file, in Gambit
Old   April 26, 2005, 00:40
Default set boundary condition in Neutral file, in Gambit
Vito Chow
In Gambit, when setting "Solver->Generic" so as to export Neutral file, there are only two boundary condition types, ELEMENT SIDE & NODE. Anybody know how to introduce other BC types, such as , wall/mass flow inlet when exporting Neu file? (not *.msh). Any help will be appreciated!
Old   April 26, 2005, 07:43
Default Re: set boundary condition in Neutral file, in Gam
Mehdi Ghoddosy
Dear Vito: You can not set your proposed boudary condition in gambit. You can simply set differt boundary condition names in gambit and then change it to appropriate type in fluent.(you can change all boundary condition types in fluent but not names)
Old   April 26, 2005, 07:50
HVN
As I remember, with the neutral format you could only export the mesh not the boundary conditions.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
