April 22, 2005, 17:50 |
Mass Velocity Direction
I'm attempting to solve a 2D, axi-symmetric, unsteady problem. I wan't to use mass-velocity-inlet boundary condition at a curved external boundary and I wan't the direction of the mass flux to be normal to the boundary and inside the domian. Since by default FLUENT takes the positive normal direction to a face as pointing outside the domain, I should give a negative mass flux, but the FLUENT doesnot accept negative mass fluxes. One method I have used to overcome this problem was to write udfs giving the direction vector for the mass flux at each point of the curved boundary. The udf uses the F_AREA command to calculate the components of the normal vector at each point, multiplies them with a minus sign and then returns them to FLUENT. When I use this method in FLUENT everything goes OK for 1 or 2 timesteps but then the direction reverses. I don't know why this is happening? I'll be glad to accept any help in this regard.
Sincerely, Saad |
April 23, 2005, 04:52 |
Re: Mass Velocity Direction
1)without using mass-velocity-inlet, u better use velocity with vector direction.
2)If you know the x,y velocity components for the x,y coordinates of your inlet, then Define-> Pofiles -> Write ... 3)for longer inlet domain, you may want to solve for a developed inlet domain and use that as an input of the original domain.. that will save ur computational time.. MNHK |
Velocity direction vertical to wall | simpleg | Main CFD Forum | 0 | February 9, 2011 23:37 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to set pressure BC with mass Velocity Magnitud | arwang | FLUENT | 2 | March 12, 2007 20:04 |
Velocity inlet calculated from Mass Flow Rate | Anthony | FLUENT | 1 | January 29, 2007 13:59 |
problem defining inlet velocity direction | salman | FLUENT | 3 | January 3, 2007 11:34 |
