CFX vs. Fluent
Old   May 4, 2005, 11:26
Default Re: CFX vs. Fluent
  #41
zxaar
actually i asked that because in my code i use cell centered approach, and i was wondering if vertex based implimentation is something that i am missing and if there is something useful i might consider using it in my code, i guess on highly skewed meshes to keep solution stable i can use node based smoothing of variables (that is based on nodes i can average value of variable at cell center and there is one value of variable which is calculated by solving linear system, so i can introduce some error function to improve the solution).
Old   July 6, 2009, 10:44
Volker Pawlik
Volker P. is on a distinguished road
I think just the opposit eis right.
Volker P. is offline   Reply With Quote
Old   November 12, 2011, 13:21
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by Guy
;120364
There is still quite a difference in hex meshes, since in a vertex scheme, integration points are located on each sub-face (the faces of each element sector around a node), whereas a cell-centered method only has integration points at the cell faces. For a hex mesh, this means CFX has 24 integration points per control volume, as opposed to 6 integration points with Fluent.
-Guy
Is this true, Can any explain to me how?
Far is offline   Reply With Quote
Old   May 16, 2012, 00:42
Sonam
sonam is on a distinguished road
Hello, I am relatively new to this ANSYS Fluent or ANSYS CFX. Since, I am doing my thesis on Windstorm damage Assessment on Traditional Roof ( i.e maximum 3 storeyed) with Corrugated Galvanized Iron(CGI) sheet) over the timber rafters. I want to do numerical simulation for Gable and Hip roof using ANSYS software. Please suggest me, ANSYS Fluent or ANSYS CFX will be good for my problem. Thanks!
sonam is offline   Reply With Quote
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 03:54
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 14:14
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 15:22
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 16:02
