More Error Messages
Old   April 22, 2005, 06:38
Default More Error Messages
Ale
Hi, what about these Error Messages? Do you know what do they exactly mean? Any clue?
Thanks a lot!
Ale
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 1: Cell_Function_Values: unrecognized function: uds-0-scalar
Primitive Error at Node 0: Cell_Function_Values: unrecognized function: uds-0-scalar
Error: Unknown object encountered in garbage collection Error encountered in critical code section
Process [0] exited with status [1] Process [1] exited with status [1] MPIRUN exited with status [0]
Error: floating point exception Error Object: #f
999999: mpt_write: error: write failed trying to write 8 bytes: No such file or directory The Parallel FLUENT process could not be started.
Old   April 22, 2005, 08:38
Default Re: More Error Messages
pUl|
If you're using a UDF in your case, check it. It is most likely not parallelized properly.
