Using UDF to define boundary conditions
Old   April 21, 2005, 18:24
Default Using UDF to define boundary conditions
Forest
Hi all, I was wondering how Fluent defines Neumann boundary condition(first derivative is zero)? I am thinking it should be done by UDF, is there an example in Fluent help? thanks a lot. best,F
Old   April 22, 2005, 04:26
Default Re: Using UDF to define boundary conditions
P
Could you please explain more for which equation you want newmann boundary condition?
Old   April 22, 2005, 12:30
Forest
Actually I intended to set 3 comp of velocities's 1st derivatives as zero at a velocity_outlet boundary. I tried to use "DEFINE_ADJUST" to take out the velocities at the cells next to the boundary cells and use "PROFILE_DEFINE" to set the boundary velocities same as those I took. Good news was it worked! the derivatives were almost zero. Bad news was that results were not convergent due to continuity residue. Probabley my model was not that good. Any better way to do the Neumann BC for velocities? thanks!
Old   April 22, 2005, 18:58
Saad
If you are using the Neumann B.Cs to simulate a fully developed flow then you should know that a fully developed flow boundary condition (which means all normal derivatives of all orders are zero at a boundary) is not mathematically consistent with the N-S equations. You should use the 'Outflow' Boundary Condition in the FLUENT instead of writing a udf, which in addition to putting the normal derivatives equal to zero does some other things to ensure a consistent solution.
Sincerely,
Saad
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Help with boundary conditions Dan CFX 0 April 3, 2006 12:32
How to Define Pressure Boundary Conditions? Sheenu Main CFD Forum 4 May 12, 2000 13:52
