Why would backflow appear?
Old   April 19, 2005, 12:11
Default Why would backflow appear?
easycad
Hi All! I am simulating a flow of liquid on a plate inside a vessel. Simulation area has 1 vel inlet and 3 press outs. Operating pressure 101325, gravity enabled, flow is laminar, gauge press at pres outs is 0, velosity at inlet is 1 m/s. The problem is that there appears backflow from the bottom, however there shouldn't be any. The backflow has relatively high speed and screws up the liquid flow (generates waves on the surface, breaks down into droplet etc). What could be the problem?
Thanks in advance!
Old   April 19, 2005, 17:39
Default Re: Why would backflow appear?
easycad
Ok! I found the answer, i had to enable operating density for lighter phase and use implicit body force. Now it works fine
Old   April 19, 2005, 20:39
pUl|
I would not be so sure. I would advise you to check whether the results make physical sense.
Old   April 20, 2005, 00:43
easycad
So far it seems that it has physical sense, at least results look as anticipated. Nevertheless if anybody has any ideas, would be appreciated!
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
how to prevent backflow? May Lim FLUENT 2 June 20, 2007 13:17
backflow temperature specification jonglee FLUENT 0 April 20, 2007 05:57
Problem with integrals and averages if backflow?? Amit FLUENT 0 October 19, 2006 19:54
Swirl in backflow on pressure outlets Jonas Larsson FLUENT 17 February 3, 2000 03:14
