flow arround porous block
Old   April 16, 2005, 07:40
Default flow arround porous block
Rachid
Hi I am modeling a heat transfer flow in channel with porous block (partielly blocked). I have problem to specify the interface prous/clear fluid. thanks.
Old   April 16, 2005, 13:22
Default Re: flow arround porous block
Amir
You should define the porous region as a seperate surface and name it differently in Gambit while you're making your model. Then activate the porous region condition in the Fluent when imported.
Amir
Old   April 18, 2005, 07:23
Rachid
Hi Amir, How I can define the realtion betwwen the two faces (in 2D), subrtact the block face from the channel face or slight the faces?
Old   April 18, 2005, 10:19
Amir
You should geometrically divide your porous region from the main region in order to be able to define the specific porous region boundary conditions on that.
Old   April 19, 2005, 09:41
Rachid
the tow face have connected edge or sepate edge (the edge that separate faces is common or each face has prpoer edge).
Old   April 19, 2005, 09:44
Amir
Edge is common
rotating porous media in a general flow a_dores FLUENT 0 October 31, 2010 05:50
Flow through the box filled with stones - porous? Luk_Fiz CFX 5 July 28, 2010 08:52
Material identification between a flow domain and a porous domain Ervideiro CFX 1 June 1, 2010 10:50
Need help!:Particle flow through porous zone lig FLUENT 0 April 26, 2010 01:47
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
