syntax error on line 1
Old   April 15, 2005, 10:43
Default syntax error on line 1
Radboud
Dear reader,
We have recently updated to fluent 6.2.16 from 6.1.22, and my udf, although it ran before, no longer compiles (interpreted mode). I receive a syntax error on line 1, which is a comment line. If I take away this line a syntax error is reported on the DEFINE_PROFILE line (see code below). The udf.h is in the default folder, and my case . We run Fluent on a linux machine.
/* comment */ #include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; real t = CURRENT_TIME; real pi; pi=3.14159265358979; begin_f_loop(f, thread) {
F_PROFILE(f, thread, position) = .04*sin(2*pi*t); } end_f_loop(f, thread) }
I hope someone can help me, thanks in advance
Radboud
Old   April 15, 2005, 11:08
Default Re: syntax error on line 1
rom
i tried your udf on my winxp flu 6.2.16 machine and it worked in interpreted mode. your problem must be somwhere else.
rom
Old   April 15, 2005, 11:17
Radboud
thanks for trying, I appreciate the effort. A likely guess would be a problem with our upgrade, but if anyone has other ideas, I'd be interested in hearing them.
best regards
Radboud
Old   April 15, 2005, 12:42
Ale
Hi
I tried to interpret your code on Windows Fluent 6.1.22 and had no problems. I think the problem is not your UDF, but something wrong with the interpreter. Check the intepreting procedure in unix.
Regards,
Ale
Old   April 16, 2005, 12:39
Swarup
do you need to use math.h for sin function?
Swarup
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
