regarding reacting flow with coupled solver
Old   April 15, 2005, 00:06
Default regarding reacting flow with coupled solver
kiran
Hi all
i am solving reacting flow of H2-Air one step mechanism with coupled solver.while solving it is not taking the reaction and not producing H2O. In control panel flow, turbulence parameters and solid have the URFs,but there is no fluid zone. inlets are mass flow inlets and exit is pressure outlet. If anybody knows pls clarify the doubts. i am very thankful to u.
regards
kiran
Old   April 15, 2005, 02:46
Default Re: regarding reacting flow with coupled solver
rom
what reaction machanism do you use? finite rate, eddy dissipation, edc? for eddy dissipation fluent needs some product species to get the reaction started. try to patch some hot steam into your reaction zone.
rom
Old   April 15, 2005, 05:57
eshwar
Hi rom
thank u for ur response. i am using finiterate/eddy dissipation for reaction mechanism.i given mass fractions at inlets for H2 is 1 and O2 is 1 in the respective boundary conditions.i am not given anything to H2O at inlets. i patched some heat source around 1900K. but coupled solver is not taking reaction and during iterations mass fraction of H2O is 0. my domain model is thrust cahmber which consists of a striaght cylindrical portion followed with converging diverging nozzle. pls give suggestions regarding convergence of solution.
thank u once again regards kiran
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 07:12
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
switching from coupled solver to segregated Oz FLUENT 2 November 8, 2006 17:02
Coupled Solver issues Allan Cross FLUENT 3 August 2, 2004 07:48
