April 14, 2005, 13:26 |
2D Fuel Cell Modeling
I have few difficulties in 2D PEM Fuel Cell modeling, Can anyone guide/suggest me on following topics Domain Coupling UDFs for SOURCE TERM in Momentum & Species Transport equation. UDFs for Electrochemical Equation, which is required to obtain current density along Fuel Cell. would appriciate any help. thanks. |
April 16, 2005, 12:08 |
Re: 2D Fuel Cell Modeling
Try searching on scholar.google.com OR Scirus.com or other search engines for scientific articles. Some 3D modeling work has been done already. You will find many papers on scholar.google.com. UDF for electrochemical equations is very specific thing. you will have to read UDS for other things. Try journals like J. Electrochemical Soc., J. Power Sources. One Dissertation by P T Nguyen reports work done on CFX. (http://www.iesvic.uvic.ca/library/pu...ion-Nguyen.pdf) Best of Luck,
Swarup. |
August 7, 2012, 07:47 |
History repeat it self
guess what happenHistory repeat it self.
I have the same problem as you I am using the Fluent 14 and I want to simulate a PEM fuel cell. The only tutorial of PEM fuel cell of Fluent is from 6.3 version. I use it to Fluent 14 and I follow the steps but the results does not the same, also some data and parameters are different. Anybody know if the tutorial of 6.3 Fluent is working to Fluent 14 too? I think now you had finish your thesis peacefully. Can you help me to overcome my problems. or send me your cas files. Thank you Emad G. elemad1987@gmail.com |
April 18, 2020, 13:11 |
Rep Power: 6 |
hello,
i have problem with 2d mesh. the fluent doesn't accept the mesh. can any one help me? send tutorial or send case files for me alamir3182020@gmail.com |
PEM fuel cell modeling | alimech | Main CFD Forum | 4 | April 18, 2020 13:15 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
PEM Fuel Cell Modeling with OpenFOAM | Berker | OpenFOAM | 1 | May 3, 2009 19:16 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
