Fluent 6.2 slower than 6.122?
Old   April 14, 2005, 00:41
Default Fluent 6.2 slower than 6.122?
Riaan
Hi guys,
I recently upgraded to 6.2 from 6.122. If I run exactly the same case with the same settings in 6.2 - it estimates 14hours for 3000 iterations....while 6.1.22 estimates 10 hours !
Thats 4 hours difference ! Any comments, suggestions? Why is 6.2 running slower?
Old   April 14, 2005, 17:41
Default Re: Fluent 6.2 slower than 6.122?
Evan Rosenbaum
Is it *actually* running slower, is is it just a bad estimate?
Old   April 14, 2005, 20:18
Riaan
After checking again, I think the estimates are off in the beginnning. I can start the same case several times and the estimates will be way out.
I do not know what is causing this, but if it does it, all I do is restart and rerun and then it seems to be better.
Old   April 15, 2005, 00:29
pUl|
If you're using Windoze, you should place as little confidence as you can on the time for iteration statistics.
Old   April 15, 2005, 18:44
ap
Definetly. With the Eulerian model, which is the model I use more often, it's slower.
ap
Modelling steam-dry reforming of methane in FLUENT 6.2. Talliks FLUENT 0 March 2, 2010 07:55
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Fluent 6.2 and 6.3 compatibility Ale FLUENT 0 July 31, 2008 04:47
Implementing own PDF in to fluent 6.2 and higher Paul FLUENT 0 August 6, 2007 11:47
Fluent 6.2 or 6.0? oliver FLUENT 0 June 12, 2007 12:17
