Limit on Number of monitors?
Old   April 13, 2005, 18:47
Default Limit on Number of monitors?
noName
Is there a limit on the number of monitors one can have in a simulation? I have created approximately 650 point surfaces and correspondingly 2 monitors for each point (U and V).When I try to run the simulation, the solver starts creating the required output files, but oddly errors out after writing out 508 files. This is the error I get:
Error: sopenoutputfile: unable to open file for output
Error Object:"output-0793.MON"
Files "output-1302.MON" to "output.0794.MON" are created successfully. This problem has nothing to do with the point surface itself, as removing monitor #793 shifts the error onto the next file.
Any suggestions?
Old   April 14, 2005, 00:12
Default Re: Limit on Number of monitors?
pUl|
Sounds like a bug to me, did you check their bugs list on the User Services Center?
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
