sloshing simulation
Old   April 13, 2005, 12:18
Default sloshing simulation
nabeel mohsin
hi everybody i am doing simulation of sloshing effect of moving cylinder filled 90 percent with water and remaining air can any body help in this regard i am using vof any help no rotational velocity is given in this simulatio can any body tell me thanks in advance and plz answer quickly nabeel mohsin
Old   April 14, 2005, 08:04
Default Re: sloshing simulation
edi ghirardi
Well,
-solver>unsteady>1st order implicit -multiphase>VOF>implicit body force ON -if you have baffles inside, SLIT THEM! -set the lighter phase as phase-1 OP CONDITIONS -turn on gravity, be careful about the signs of the components -operating density, the one of the lighter phase -pressure location: a point where the lighter phase is. SOLUTION -U-R Factors: pressure 0.6 momentum 0.8, 1 the others. -discretization: body force weighted for pressure, PISO for pressure velocity coupling (PISO parameters: skewness correction 0, neighbor correction 1), first order upwind for momentum.
initialize the flow field, and then
-adapt>region set the coordinates where water is and click mark. -solve>initialize>patch: under phase choose water, under variable volume fraction, under value 1, under registers to patch the region you marked, than patch.
Basically that's what is it.
hope it helps,
Edi.
Simulation of sloshing by time varying gravity Manoj Kumar FLUENT 3 June 13, 2011 04:34
how simulation sloshing putexx FLUENT 0 February 3, 2011 01:13
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 19:57
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 14:02
