How to set transient ang velocity?
Old   April 12, 2005, 10:34
Default How to set transient ang velocity?
edi ghirardi
Hi to everybody,
I'm studying liquid sloshing in a partially filled 3d tank submitted to transient linear accelerations and transient angular acceleration around one axis. I set the transient linear accelerations via a .scm file that reads an input file and changes the gravity components in the Operating Conditions panel depending on the time step. Up to now I'm able to set a constant angular velocity by the Bound. Conditions>Fluid>Moving Reference Frame option (I also set the walls as Moving Walls rotating at 0rad/s referring to the adjacent cell zone). How can I do to change it during time? Is it possible to use another .scm file or what?
Grazie (thanks),
Edi.
How to set Solution Initialization in transient jasonzhang2000 FLUENT 2 June 17, 2010 08:54
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
transient velocity for wall:UDF or Profile Modisa FLUENT 5 March 7, 2007 08:30
Cannot set correct inlet velocity by UDF?!? Bob FLUENT 5 March 27, 2003 04:17
Transient Velocity BCs Chris Morgan Main CFD Forum 1 May 13, 1999 16:19
