UnSteady Boundary Conditions - Changing with time
Old   April 11, 2005, 15:03
Default UnSteady Boundary Conditions - Changing with time
Docker
I want to simulate an inlet valve in an engine.
Therefore I have a pressure outlet at the valve. The pressure is changing with time, and is defined with a UDF (User-Defined-Function). This works...
However, I want to change the outlet boundary condition to a 'wall' when the valve is closed.
Docker
(I have been using a journal file, but at the moment it is not reading in proporly, if anyone knows the correct order of commands and syntax, for changing boundary conditions at time steps, that would be great!)
Old   October 9, 2009, 14:49
Smile help me creating a udf for pressure varies with time
madhu sudhan
madhu31 is on a distinguished road
hi i need ur udf file for pressure changing with time.because i have to simulate a flow for a pipe and i have write udf to determine pressure unsteadiness in pipe.
madhu31 is offline   Reply With Quote
Old   October 24, 2009, 09:30
Zenith is on a distinguished road
HI , I need ur UDF too.
I'm trying to do UDF about pressure profile.
help me please.
my e-mail :san_36c3@hotmail.com
Zenith is offline   Reply With Quote
Old   July 13, 2011, 06:06
Sergiu Stroe
Sergiu is on a distinguished road
help me please.
Hi Zenith,
I need also that UDF file, did you received from the collegues?
can u help me?
Sergiu is offline   Reply With Quote
Old   July 14, 2011, 12:01
Default air flow and unsteady boundary conditions
Nasos
Nasos is on a distinguished road
I have to simulate the air flow and calculate the ventilation rate of a building under unsteady conditions. Since the air flow inside the building is dominated by the outside conditions (wind speed, wind velocity and air temperature), how can I solve the problem under unsteady conditions. I have experimental data for outside every 5 min. How can I set these data as boundary conditions?
Nasos
Nasos is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
