moving boundary(normal to surface)
Old   April 7, 2005, 12:30
Default moving boundary(normal to surface)
sairamesh
sir i m doing a problem in which one boundary has a velocity normal to its surface is there any possibility of giving such a condition in fluent if possible please tell me how to model this type of boundary condition ramesh
Old   April 7, 2005, 12:34
Default Re: moving boundary(normal to surface)
Luca
Unfortunately no. I had the same problem. You can only set a tangential velocity ot use the dynamic mesh. Luca
Old   April 7, 2005, 12:41
sairamesh
can you send me your problem
Old   April 7, 2005, 17:25
Luca
Hi wanted to use transpiration velocity for aeroelastic analysis of a wing. Fluent ignores the normal component velocity and accepts only the tangential one. Maybe you could try using the velocity inlet profile instead of a wall but you shuld make sure it works well. This condition may work only with the segregated solver if you want to model an inlet or outlet velocity (see the guide). Luca
Old   April 9, 2005, 02:49
Anatoly
Greetings! I have some experience of modelling of free vertical fluctuations of the Vertical cylinder on border of the unit of phases water - air. The bottom and top end faces of the cylinder thus move on a normal on distance of m from ÿ the cylinder. I think, that it approximately that interests you. Can state the problem(task) on mine more in detail anatoly46@gtn.ru. Anatoly.
Old   October 11, 2016, 18:15
mhs
mhs is on a distinguished road
Originally Posted by Anatoly
;119481
Hi Anatoly
I want to simulate a cylinder that has an axial moving in a non-newtonian fluid.
from one end of cylinder, there is an exhaust of fluid (B.C : velocity inlet ). how can I set this condition that a surface (one end of cylinder) with velocity inlet B.C, can move in a line with given velocity?
best regards
mhs
mhs is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 13:19
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
Free surface moving boundary zou_mo OpenFOAM Running, Solving & CFD 3 December 28, 2005 21:33
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
