Help! Total heat transfer rate doesn´t sum to zero |
i´m modelling a natural convection and radiation (do) problem. After 6000 Iterations (steady case) the residuals have flatten down (continuity =1e-2, the velocity, k, epsilon are at about 1e-4, energy and discrete ordinate 1e-6). But the sum of the "total heat transfer rate" for all boundaries is far away from zero. It is at about 5000W. My inlets and outlets have a total heat transfer rate between 4000 and 6000W. Is this a indicator that my solution isn´t total converged? After 17000 iterations it´s still the same problem. After that I built up a small problem to investigate this behavior. The result: The total heatflux sum to zero. I would be pleased for any kind of help! Thank you! |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
total pressure influence on heat transfer | fab | Main CFD Forum | 8 | May 19, 2005 09:24 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Turbulent wall heat transfer rate? | Tom | Main CFD Forum | 1 | March 1, 2001 05:51 |
