Fluent cases in parallel across multiple machines |
Hi guys, today I have a question on running Fluent in parallel across multiple machines.
I have run it in -t2 mode on a single PC with dual Cpu's...but unfortunately the unsteady cases that I am running still take too long. I have four 3.4Ghz P4/2Gb machines available. Here are some of my questions: 1) Do I have to copy the case and dat files onto each computer 2) Do I need to start Fluent on each computer? Any tips/advice would be appreciated! Regards Riaan |
1) Do I have to copy the case and dat files onto each computer?
NO 2) Do I need to start Fluent on each computer? NO, just one will do. |
Ok, so I managed to get the network guys to unblock the Fluent network pop-ups that got blocked by the Firewalls.
How do I start Fluent across 2 Windows XP machines? Do I need to specify IP adress? |
Start Fluent in one machine and the start spawning nodes. Refer to the user manual for more information.
Parallel fluent not using all processors specified | Paul | FLUENT | 18 | October 26, 2023 03:54 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Issue with running in parallel on multiple nodes | daveatstyacht | OpenFOAM | 7 | August 31, 2010 17:16 |
parallel calculation on multiple computers | foam_noob | OpenFOAM | 4 | February 3, 2010 03:14 |
Fluent Parallel Error | Will Humber | FLUENT | 2 | April 3, 2008 14:15 |
