April 5, 2005, 07:21 |
Skewness
hi, I have a 3D model that have high skewness values. However whatever I do for lowering skewness values didn't work. The worst element has a skewness of 0.82. What should the limits of skewness be for analyzing a turbulent flow of air around a body? is 0.82 anyway ok? Thanks Regards Taskin
April 5, 2005, 07:29 |
Re: Skewness
I have read that maximum skewness value should be around 0.5.
April 5, 2005, 07:42 |
Re: Skewness
then I should decrease it in some way thanks Regards Taskin
April 5, 2005, 08:32 |
Re: Skewness
what? the max skewness should be 0.5? in my mesh ,it often exceeds 0.9. because i use dynamic mesh, sometimes over 0.95, and there will be a warning. so, i should remash it?
April 5, 2005, 09:25 |
Re: Skewness
Yes, handou is right. The limit should be anyway 0.9 not to have excessive skewness. Luca
April 6, 2005, 15:21 |
Re: Skewness
From my experience, try to stay under 0.75.
Up to 0.85 is acceptable, but not good. Above 0.98 - and Fluent Grid check will fail. Also when you use such skew cells, it makes sense to go to 2nd order methods for density, momentum etc. |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
TGrid High Skewness | khimkhim | ANSYS Meshing & Geometry | 1 | February 17, 2010 23:36 |
problem with skewness | jjchristophe | FLUENT | 1 | January 14, 2010 21:22 |
Severe nonorthogonality and severe skewness problem | qtian | OpenFOAM Running, Solving & CFD | 2 | January 22, 2008 18:47 |
Skewness & Decomposition | Marc | FLUENT | 2 | July 5, 2007 14:54 |
