Turbulence modelling
Old   April 5, 2005, 07:11
Default Turbulence modelling
joe Nwaejike
Hi, Is it possible to model fairly accurately low reynolds number turbulence of a tall enclosed cavity undergoing buoyancy convection on fluent 6.0/6.1 using the k-epsilon model? Joe
Old   April 5, 2005, 13:22
Default Re: Turbulence modelling
Evan Rosenbaum
Unfortunately, the answer is "it depends". In some cases it might be OK and in others not. If you go into the transitional regime, all bets are off. You will need to compare your results with test data for some sort of similar condition no matter what you do if you want to concretely confirm your results.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Homogeneous Turbulence Modelling Zaktatir CFX 0 December 15, 2010 10:37
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Turbulence modelling Panos Siemens 6 July 8, 2004 03:40
