Porous Media as solid object
Old   April 2, 2005, 19:07
Default Porous Media as solid object
Tom
Hi guys, is it possible to use a porous element (with porosity set ted equal to 0) instead of a solid element? I've difficulties in turning off fluid fluxing throught. Thaks and regards to everyone.
Tom
Old   April 3, 2005, 13:31
Default Re: Porous Media as solid object
Amir
The porosity is not basically accounted for if you're solving for the flow equations. It implicitly shows its effect in the resistance coefficents. However, porosity affects the energy equation if you're interested in solving that.
Amir
Old   April 4, 2005, 13:46
Evan Rosenbaum
The porosity is only used in determining the thermal conductivity, density and heat capacity of the porous medium. If you are doing fluid-flow only, you can increase the porous media resistance to a very large number and effectively stop through-flow. You cannot do this with heat transfer.
Why don't you just change the zone from fluid to solid?
Old   April 6, 2005, 09:28
Default residence time distributation help
Yazid
Hi ,which is the easiest method for RTD ??
Old   April 11, 2005, 08:52
Tom
Thanks to veryone.
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
