Steady problem and unsteady mode
Old   March 31, 2005, 22:55
Default Steady problem and unsteady mode
mini
Hi, Can I use the unsteady mode to simulate the steady problem? Thanks.
Old   April 1, 2005, 01:07
Default Re: Steady problem and unsteady mode
hongxiao
sure
Old   April 1, 2005, 03:37
debs
The accuracy of the algorithm reduces when you use the unsteady mode for a problem which looks steady.
Old   April 1, 2005, 09:14
ap
Each steady problem can be considered as the "final" state of an unsteady problem.
So you can simulate a steady case considering its evolution in time, waiting until it reaches the steady condition and averaging on a proper time interval.
Best regards, ap
Old   April 1, 2005, 17:22
Suggestion
You will need to be sure though that you do not have an undsteady case. i.e. a flapping jet or vortex shedding etc. In these cases you will not have a steady solution.
Old   April 1, 2005, 19:12
ap
Well, sure.
You can simulate a steady case as unstedy. The viceversa is obviously not true.
Regards, ap
Old   April 3, 2005, 21:28
mini
Thanks.
steady RANS for flow problem with unsteady inlet? kat Main CFD Forum 0 February 16, 2009 11:24
Unsteady AND Steady mode for Fully Developped Flow Dominique FLUENT 5 April 16, 2004 18:58
steady and unsteady Euler eq problem AO Main CFD Forum 3 January 27, 2004 17:29
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 12:30
Why does unsteady problem tend to be steady? wang Main CFD Forum 15 February 21, 2002 07:11
