Dual processor system
Old   March 30, 2005, 14:07
Default Dual processor system
Allan Walsh
We just upgraded to a dual processor workstation to run Fluent on, under Windows. We are working with Fluent to upgrade our license so that we can use the second processor, I guess by running the parallel version of Fluent.
When I run a serial version of Fluent on the dual processor workstation, and look in with Windows Task Manager, I see that Fluent is using both processors, but each processor is limited to about 50% (typically 50% to 53%).
So, first, why is each processor only limited to half? And, second, what advantage is there to running the parallel version if the serial version can already use both processors?
I know hyperthreading will limit Fluent to only 50% of processor use, but hyperthreading has been disabled in BIOS.
Old   March 30, 2005, 14:16
Default Re: Dual processor system
Evan Rosenbaum
Running serial on a dual-CPU box swaps the process back and forth between the two processors. If you use PERFMON to monitor the load on each CPU, you see that one is up when the other is down. The serial version will never use more than 50% of each CPU (on average).
The advange of parallel is, therefore, that you can use ~100% of each CPU.
Old   March 31, 2005, 05:34
Charles
If you are running Windoze it is easy to set the solver process affinity (use the Task Damager, right click on the solver process and set the affinity) so that the single solver process runs on one CPU only. That will give you nearly 100% on one CPU and 0 on the other. I'm not sure that doing this helps at all. Parallel is the obvious way to go.
Old   March 31, 2005, 15:39
Allan Walsh
Thanks guys for the comments. After spending some more time looking at it, and getting input from Fluent support, I started getting the impression I was being misled by Windows Task Manager.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
recover solution from dual grid jamesproctor Main CFD Forum 0 July 30, 2010 16:31
Dual Xeon PIV 3.8Ghz vs 2x Dual Core E5130 2.0 GHz Michiel Hardware 4 July 31, 2009 07:06
How many CFX licenses for dual core processors? km CFX 12 September 8, 2006 16:18
