about axis symmetric cases
Old   March 24, 2005, 05:44
Default about axis symmetric cases
Masood
hi i want to analyze annular flow in circular channel.i can use axissymmetric case. but how i define axis as it is out of the flow area and only mesh is imported in fluent. i used gambit for preprocessing.
Old   March 24, 2005, 13:34
Default Re: about axis symmetric cases
Evan Rosenbaum
Your axis of symmetry must be the x-axis.
Old   March 24, 2005, 14:00
Masood
hi rgr m8, thanks. i made the x section at required distance(radius) and then meshed it and export . but fluent didnt showed the coordinate system or saying the origin. so i can see that my flow area is above the x axis and not on it. i suppose that the origin is same as in gambit. or every thing will loose its sense.
Old   March 31, 2005, 16:02
ap
Yes, the origin is kept the same.
Best regards, ap
[DesignModeler] axis display disparity of model and triad ram881973 ANSYS Meshing & Geometry 14 November 18, 2020 02:21
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 17:35
axis symmetric + swirl bthomas OpenFOAM Running, Solving & CFD 0 April 12, 2011 19:48
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 15:36
CFD Validation Cases doug Main CFD Forum 4 January 11, 2010 20:28
