March 23, 2005, 11:51 |
about symmetry BC
dear user,
if we use symmetry BC, should we have to double the forces to obtain the total force on the body. expecting ur reply sulfi |
March 23, 2005, 12:30 |
Re: about symmetry BC
Yes, in Fluent you have to double the force to obtain the total force when using a symmetry condition. The other option is that if you look at the force coefficients instead, use half of the reference area and that will give you a force coefficient for the entire model.
Just a side note, this topic has been discussed several times before on the forum. This is the same for many other topics. For a quick answer to your questions, search the forum and archives first. If you can't find what you're looking for, then post your problem. Hope this helps, and goodluck, Jason |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 04:13 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 15:26 |
Forces in Symmetry | Matt | CFX | 2 | February 25, 2009 06:41 |
Symmetry plane error in solver | Santiago Orrego. | CFX | 6 | January 31, 2007 08:09 |
radiation and symmetry | Mark | FLUENT | 2 | November 4, 2004 14:50 |
