Cavitation
Old   March 19, 2005, 11:31
Default Cavitation
Atzaru
Hello!
I am simulating the flow inside diesel injectors, particularly being interested in the cavitation phenomena. Unfortunately the problem is very unstable. Very strange flow behavior is predicted by fluent. In the new version 6.2 even the old tutorial(for 6.1) file "cav" does not work.
The turbulence model is Spalart Allmaras, Pressure-Velocity Coupling SIMPLEC, discretization second order for al eq.
Does anybody have dealt with this kind of calculations? Some suggestions?
Many Thanks
Atzaru
Old   March 19, 2005, 20:03
Default Re: Cavitation
Jörn Beilke
Have a look at this:
http://www.nabla.co.uk/main/mainhe36.html#cavitation
Since Foam is open source now you can try using it instead of fluent.
Old   March 22, 2005, 08:20
mateus
Hi!
The model in fluent version 6.1.18 and later works ok if you make unsteady simulation. I have never achieved a stable simulation (with reasonable results) for a steady case...
hope it helps MATEUS
Cavitation Problems Chris Siemens 4 July 17, 2005 17:47
Cavitation inception problem newuser FLUENT 3 May 13, 2003 12:14
Cavitation Simulation by CFD Liu, L. CFX 2 November 29, 2000 14:50
Cavitation Simulation by CFD Liu, L. Siemens 2 November 1, 2000 22:51
Cavitation Simulation by CFD Liu, L. Main CFD Forum 7 November 1, 2000 22:26
