error trying to migrate from Linux to Windows
Old   March 17, 2005, 16:50
Default error trying to migrate from Linux to Windows
DavidSF
Hello everybody, I'm working on a Linux system and I'm trying to migrate to a Windows computer. When I read my .cas file in Windows an error appear:
Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 3.6e+14) (profile "" "")) ..... .....
I think .cas files are ASCY, aren't they?
Somebody knows where is the problem????
Thanks in advance
Old   March 17, 2005, 21:06
Default Re: error trying to migrate from Linux to Windows
pUl|
Not if you checked the 'write binary files' option while saving the case. If you're using ftp to grab the files, make sure binary mode is turned on.
Old   March 18, 2005, 06:20
DavidS
I've checked it, but the error is still here. I'dont know what to do...
Old   March 18, 2005, 19:25
pUl|
You are NOT supposed to check that option if you want to transfer the file in ASCII mode.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 16:39
Linux to Windows (dual boot system) Alex Main CFD Forum 9 May 3, 2007 04:36
