urgent-reacting flow modelling in thrust chamber
Old   March 17, 2005, 04:58
Default urgent-reacting flow modelling in thrust chamber
eshwar
Hello all
i am modelling reacting flow in liquid rocket thrust chamber with H2-air one step model.
In the model two inlets for fuel and oxidizer and one outlet pressure conditions.
i tried so many times divergence detected in my problem. 1) how to give the exact pressure boundary conditions at inlet and outlet.
2)what is the solution procedure for compressible species transportation problem.
if anybody knows about this problem please send the information . i am very thankful to u. waiting for ur reply. bye.
Old   March 24, 2005, 00:03
Default Re: urgent-reacting flow modelling in thrust chamb
Kumar Swamy
One possibility may be in for compressible flows, the inlet conditions are defined as mass-flow rates instead of velocity inlet.
regards kumar
Old   March 24, 2005, 06:01
eshwar
thank u kumar.
but i am getting divergence detected in temperature and floating point error and invalid number. how can i overcome this problem? if any body knows about combustion modelling in fluent pls send suggestions.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 18:16
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 09:04
Flow and Heat transfer in a Thawing chamber B.Prabhu FLUENT 0 May 12, 2002 16:13
modelling flow in microchannel Wang FLUENT 6 October 10, 2000 10:28
