wall function and grid
Old   March 16, 2005, 08:39
Default wall function and grid
Y
hi I am simulating flow behind a bluff body. Not I know that if I want to use the wall function. the y+ plus values should not be less than 11 and greater than 60. How can I make delta x of the first node to the value which I require and use the structure grid i.e delta x in other cels are equal and less than delta x in the first cell.
Y
Old   March 17, 2005, 05:53
Default Re: wall function and grid
Y
Its is urgent Please reply me
Old   March 17, 2005, 06:19
Stephen
just use "adapt -> Y+/Y*" in Fluent and let it adapt your mesh. However in 3D grids I have only been able to refine the grid (no coarsening)..
Stephen
Old   March 17, 2005, 07:48
Y
Hi, Is it possible to do it in gambit or not. I do not want to affects others grid distribution. Y
BSL Automatic Wall Function - Shifted koordinates Sali CFX 0 April 26, 2007 06:04
wall function and grid independency????? scott FLUENT 3 October 26, 2006 13:31
wall function and grid dependency Bob Main CFD Forum 10 April 28, 2004 03:15
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 05:05
