When I run the unsteady problem by including UDF at the vel inlet(to define the velocity profile, I do not get convergence. The residuals plots show that it fluctuates and no sign of going flat. I am modelling flow around cylinder in water. Can some one help me with this? Where did I do something wrong? Sham. |
have u calculated the Re. it might be in unsteady, thats why u r getting fluctuations.if it is in unsteady regime it will never go flat and will reach periodic steady state.
The Re is 1.4x10^5. If it is the case, how can I monitor for the convergence?
problem saving drag convergence history | raheelrasool | FLUENT | 3 | April 20, 2009 09:04 |
Continuity eq convergence problem | carno | FLUENT | 4 | February 8, 2008 04:04 |
Unsteady Boundary Layer Problem | C.J.Yoon | Main CFD Forum | 0 | January 27, 2006 04:19 |
convergence problem | Trushar | Phoenics | 5 | August 27, 2002 23:40 |
Convergence problem when ustructured mesh is used. | SangJin Ryu | Siemens | 3 | October 5, 2000 20:26 |
