March 14, 2005, 11:00 |
Is the flow turbulent?
how does one in a general geometry (not tube) decide before CFD calculations that the flow therein will be turbulent? I have a geometry that is far from being a pipe and I would not know how to calculate a representative Reynolds number therein. Thank you for your help. - Katarina |
March 15, 2005, 03:51 |
Re: Is the flow turbulent?
If I am not mistaken, wasn't hydraulic diameter for this purpose? If you have a non-circular geometry, you can obtain an equivalent diameter based on its geometry and then based on that diameter you'll calculate Re_no. There are also some other correlations if you have a particular geometry. rgds Melaku H |
March 15, 2005, 09:46 |
Hi;
I would recommend "Michel method". For details see (Viscous Fluid Flow) by: Frank M. White, 2nd edition, page 377 . One more thing, eq.(5.38) in the above mentioned Ref., was later modified by another one which require some kind of iteration to be solved; to see this new form goto AIAA 2000-0048. The above method could be easely implemented in any code -I assume !- Hoping it would help |
March 16, 2005, 06:49 |
Hello Melaku,
thanks for the response! I have a situation where I think that recirculation areas act as "walls" of a narrowing, through which fluid is squeezed. If I calculate the hydraulic diameter of the actual geometry, I will get Re that are below those that occur locally. Thanks, Katarina |
March 16, 2005, 06:59 |
Hello Khalid,
thank you, I checked out the AIAA paper, and am now waiting for the book to arrive. Cheers, Katarina |
spectrum: LES of a turbulent channel flow finally goes to turbulent | liu | OpenFOAM Running, Solving & CFD | 6 | November 1, 2011 02:00 |
Difference between recirculation zone and turbulent flow region | ashtonJ | Main CFD Forum | 0 | September 16, 2011 04:46 |
Patch a bubble inside turbulent flow | Helmi | FLUENT | 0 | February 4, 2011 05:54 |
Turbulent flow through hexagonal circular pipe | yogesh@cfd | Main CFD Forum | 0 | November 10, 2010 00:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
