flow behind a geometry
Old   March 11, 2005, 07:08
Default flow behind a geometry
pp
Hi, I am simulating flow behing a bluff body.I have read in some paper the this phenomena is unsteady as one can observe constant vortex shedding behind this body. But when i simulate this in Fluent using usteady code I do not get any unsteadiness. How can I capture the unsteadiness using Fluent code. pp
Old   March 11, 2005, 12:41
Default Re: flow behind a geometry
diet
if you are using a RANS turbulence model (k-epsilon or something like that) it's of little or no use computing it unsteady. Because RANS is a model that is meant to give a time averaged result. You'll only be able to observe any fluctuations if your inverse turbulent timescale (k/epsilon)^-1 is bigger than your vortex shedding frequency behind your bluff body.... you should perform LES, but it means that you'll have a hihger computational cost!!!
Old   March 11, 2005, 13:41
pp
What is they hysical reasons behind such an statement. "any fluctuations if your inverse turbulent timescale (k/epsilon)^-1 is bigger than your vortex shedding frequency behind your bluff body" Actually I have some papers where they perform this unsteady calculation and obatin the correct vortex shedding frequency. pp
Old   March 12, 2005, 23:05
wr
That is your turbulence time scale should be smaller than vortex shedding time scale. At least an order lower. And you mesh is dense enough!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
Is an uniform flow possible for this geometry? Michael Hu FLUENT 1 April 13, 2006 23:11
