solution not converging with UDF. Please help!! |
I am just trying to write a simple property UDF and it is not converging (blowing up on energy). i am cut-pasting the complete UDF. can someone pls tell me what i'm doing wrong? thanks #include "udf.h" DEFINE_PROPERTY(cell_viscosity, cell, thread) { real eta_carreau; real eta_carreau1; real temp = C_T(cell, thread); real pressure = C_P(cell, thread); real strain_mag1 = C_STRAIN_RATE_MAG(cell,thread); real strain_mag; real strain_term; real index_1; real tg0 = 362.82; real a1 = 0.29e-06; real c1g = 13.276821; real c2g = 48.52984; real a2 = (-c1g*(temp - tg0)); real a3 = c1g*a1; real a4 = c2g+temp-tg0; real n = 0.294539187; real a = 2.; real eta_inf = 0.0; real eta_zero = 10000.0; real lambda = 0.1; real ap1 = (a2 + a3*pressure)/(a4 - a1*pressure); real ap = pow(10,ap1); strain_mag = (strain_mag1)/(ap); index_1 = (n-1.)/a; strain_term = pow((lambda*strain_mag),a); eta_carreau1 = eta_inf + (eta_zero - eta_inf)*pow((1+strain_term),index_1); eta_carreau = eta_carreau1/(ap); return eta_carreau; } |
If everything is Ok i.e. the equation that you has no errors in it and you didn't make any typo somewhere in this code then check the following: 1. Units! - just a 5min check will save you hours of headache - I cant stress this more. 2. Check the correlation/empirical equation for what RANGE it is applicable - eg temp range? intermediate values of either pressure or temperature might cause this error. As much as possible try to stay within the range by forcing a good convergence even during the initial iteration. I included some more below #include "udf.h" DEFINE_PROPERTY(cell_viscosity, cell, thread) { /* its always good idea to initialize values if they are needed at first iteration */ real eta_carreau; real eta_carreau1; real temp = C_T(cell, thread); real pressure = C_P(cell, thread); /* remember your are getting guage pressure here - and am not sure your if equation is based on that */ real strain_mag1 = C_STRAIN_RATE_MAG(cell,thread); real strain_mag; real strain_term; real index_1; real tg0 = 362.82; real a1 = 0.29e-06; /* 0.29e-6 ? just in case */ real c1g = 13.276821; real c2g = 48.52984; real a2 = (-c1g*(temp - tg0)); real a3 = c1g*a1; real a4 = c2g+temp-tg0; /* u may check this eqn again */ real n = 0.294539187; real a = 2.; real eta_inf = 0.0; /* you might just omit this if it is always zero */ real eta_zero = 10000.0; real lambda = 0.1; real ap1 = (a2 + a3*pressure)/(a4 - a1*pressure); real ap = pow(10,ap1); /* make sure it is not the other way round pow(ap1,10) */ strain_mag = (strain_mag1)/(ap); index_1 = (n-1.)/a; strain_term = pow((lambda*strain_mag),a); eta_carreau1 = eta_inf + (eta_zero - eta_inf)*pow((1+strain_term),index_1); eta_carreau = eta_carreau1/(ap); return eta_carreau; } test it and let me know. Also u may get beeter help if you write the coorect equation up here. regards Melaku Habte |
Hello Melaku,
Thanks for your detailed analysis of my problem. The equation that i have written in my code is indeed the correct equation - i verified it a couple of times. i'll try to implement the suggestions that you have given - hopefully something will work. for now, i'll just want to thank you for caring to go through my equation and taking out time to offer constructive suggestions. i had almost given up all hope of someone helping me with my UDF. thanks. shunahshep. |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
UDF for the heterogeneous gas-char reaction rates, using a numerical solution | yummy0917 | Fluent UDF and Scheme Programming | 0 | March 9, 2011 05:44 |
solution is not converging | mkiku | FLUENT | 2 | June 28, 2004 08:01 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
