March 4, 2005, 03:52 |
help; UDF of VOF model
Hi...
I want to solve the evaporation of the water in the box. There is a heat source the wall and topper wall is opened. Is it right that define_exchacge_property as the udf function to deal with the evaporation problem is used? If it isnt, could you tell me about the correct udf? Help me.. thanks |
March 5, 2005, 01:00 |
Re: help; UDF of VOF model
I also encounter this case. Maybe you can add a mass source on the wall or define a mass flux on the wall. you can have a try. Good luck!
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
UDF for BCs in VOF model | CLINT_E | FLUENT | 4 | October 5, 2011 15:54 |
UDF, Herschel-Bulkely model don't have Yielding viscosity term | emad | Fluent UDF and Scheme Programming | 0 | May 19, 2009 13:46 |
writing UDF for modelig mass transfer for VOF | ardalan soleymani | FLUENT | 0 | July 11, 2007 02:09 |
