How to Change UDM Variable's Name?
Old   March 2, 2005, 19:32
Default How to Change UDM Variable's Name?
Zhang
Hi, Once a UDM variable is defined, it can be plotted in postprocessor and its name is like 'udm-0'. My questions are, how to change the name and how to define its unit?
Thanks in advance,
Zhang
Old   March 3, 2005, 06:48
Default Re: How to Change UDM Variable's Name?
Andrew Garrard
The easiest way I have found to do this is to create a Custom Field Function.
Old   March 13, 2005, 16:30
Zhang
That helps, thanks a lot!
Old   April 18, 2012, 10:39
TMC
Thierry
TMC is on a distinguished road
In newer version of Fluent (maybe from 12.0), you can use the function Set_User_Memory_Name(index, name_string)
I noticed this post is old but it may still help others.
TMC is offline   Reply With Quote
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 07:37
Solid/liquid phase change using large viscosity gregor.vidmar153 OpenFOAM Running, Solving & CFD 3 June 10, 2010 07:31
$FOAM_USER_APPBIN & LIBBIN variables not set rassilon OpenFOAM Installation 2 February 16, 2010 21:54
Old OpenFOAM Users, Read This if you Want to Change Username pete Site Help, Feedback & Discussions 0 March 16, 2009 05:29
UDM: statistically averaged variabls lcw FLUENT 4 January 8, 2006 03:39
