VOF with tetra mesh doesn't converge
Old   March 1, 2005, 06:02
Default VOF with tetra mesh doesn't converge
Gregor
Hi I try to use the VOF methed of Fluent with a tetra volume mesh. The skewness is below 0.6 and the aspect ratio under 3. I did a calculation with the default settings for the VOF model but the calculation didn't converge. I used a very small time step (1e-9). I did also a calculation with a structed mesh (a simplified geometrie). With this file the calculation converge very good. Time step was there 0.001. Are there any other restictions with fluent and tetra meshes. Thanks for any advice
Gregor
Old   March 1, 2005, 14:09
Default Re: VOF with tetra mesh doesn't converge
Manoj Kumar
hi Gregor
Default settings wouldn't let to convergence. Read fluent tutorials on VOF and then modify ur inputs accordingly. There are 3 vof schemes applicable to unstructured mesh. They are implicit, explicit and geo-reconstruction. Find out which one is suitable for ur problem from tutorials. And then depending on ur problem, choose steady/unsteady formulation. For geo-reconstruction, unsteady scheme is a must. For pressure and pressure-velocity coupling descritization ( solve\controls\solution ) choose body force weighted and PISO scheme respectively. u also got to enter turbulence parameters correctly, in case u are using velocity/pressure inlet.
Try these.
Manoj
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
ICEM 2D tetra mesh question kawamatt2 ANSYS Meshing & Geometry 18 March 3, 2014 11:56
[ICEM] Hugh cell jump in Tetra mesh jeevankumarb ANSYS Meshing & Geometry 3 June 2, 2010 11:45
VOF with a moving mesh Jeremie FLUENT 1 November 26, 2008 09:55
