display boundary conditions
Old   February 28, 2005, 18:27
Default display boundary conditions
Tarnz
Is there a possibility to display the chosen boundary conditions in Fluent (i.e. velocity profile, roughness height ec.)? I want to display it on a 2D surface, not as a xy plot. Thanks
Old   February 28, 2005, 19:22
Default Re: display boundary conditions
Jason
If you're running a 2D model, then you BC is only 1D... You can do plot->contours and look at a lot of things, but I don't think roughness height is an option... not completely sure though, it might be there. It'll plot the contours for the entire domain, but you can zoom into the BC you're interested in (not sure if that's what you're hoping for though).
If you're running a 3D model, then you can do plot->contours and plot the contours right on your BC.
Hope this helps, and goodluck, Jason
Old   February 28, 2005, 19:49
Tarnz
Thank you Jason. Unfortunately it never gives me the option to choose the roughness height...
Old   February 28, 2005, 21:27
Jason
Roughness height is a constant on a surface though, isn't it? Did you use a UDF or something to define a special roughness?
Jason
Old   February 28, 2005, 21:40
Tarnz
I am working with the new Beta version of Fluent and there you can import a profile file with the roughness height and constant for specifying the boundary conditions of a wall if you wish. (I try to model flow over a complex terrain with quite a patchy vegetation/roughness pattern.)
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
Boundary conditions for 2D Navie-Stockes simulation L1011 OpenFOAM 5 December 13, 2012 09:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
