Divergence of residuals
Old   February 27, 2005, 05:10
Default Divergence of residuals
Manoj Kumar
hi everone
When I start the iteration, the residuals after very 1st iteration show a very high range, between 1e-1 to 1e+6 and then after second iteration the values reduce to a smaller range between 1e-1 to 1e+1 . But after a few more iteraions it shows following error ..
Error:> (greater-then):invalid argument [2]:wrong type [not a number]
Error Object:nan0x7fffffff
Previously I was using a different mesh and for the same schemes and initial values, the solution was converging well. But then, I refined the mesh further and am facing this problem. Can this error be because of defect in the mesh? Please help.
I am using vof implicit scheme to study flow aroung a ship model. ( http://www.geocities.com/kmanoj_cool/btp/ )
Thanking you. Manoj.
Old   February 27, 2005, 05:21
Default Re: Divergence of residuals
Manoj Kumar
Is it possible to change the range of acceptable values of the residuals, so that the error doesn't comes and the iteration continues further.
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
divergence of scaled residuals (steady simulation) hanka FLUENT 6 December 16, 2010 05:45
divergence in energy residuals swarley FLUENT 2 May 22, 2008 09:09
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
