Best solver for Highly Compressible Flow
Old   February 24, 2005, 11:45
Default Best solver for Highly Compressible Flow
manish
Hi everyone,
What is the best solver for highly compressible internal flow? I am looking at a supersonic jet exiting from a converging-diverging nozzle?
What is the best CFD package that can handle this?
I am using Fluent, but I am having problems with it, and I am unsure of my results.
I would like to thank Dr. Nandu Menon, and Suman Basu for their extreme help in my research endeavors.
-Manish
Old   February 24, 2005, 13:12
Default Re: Best solver for Highly Compressible Flow
sam
Try S-A model with second order upwind scheme and make the tolerance of convergence monitors tight.
Old   February 24, 2005, 14:30
Riaan
Second order upwind scheme will not work for case where you expect shockwaves because it is not physical.
Old   February 25, 2005, 03:29
Sam
Try validating your results using experimental data. Works best for cases like these, in case you got some experimetal data. samir
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 07:12
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 14:16
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
low speed compressible flow lily CFX 2 November 16, 2005 06:15
