Extracting *.msh
Old   February 24, 2005, 03:46
Default Extracting *.msh
Y
How can I extract *.msh grid file from case (*.cas file). Please help me Y
Old   February 24, 2005, 05:50
Default Re: Extracting *.msh
Mark
If you have access to TGrid its simple. Simply load tha case file into the TGrid and then you should be able to write out the mesh file.
Mark
Old   February 24, 2005, 06:41
Y
Thanks it seems that we do not have Tgrid. Actually what I want to do is to check number of nodes in each zones. How can I do it. Y
Old   February 24, 2005, 08:11
zxaar
gambit will also do
Old   February 24, 2005, 08:22
Y
Hallo but I do not have the *.msh files only *.cas files is it possible to read using gambit *.cas and get the mesh. Y
Old   February 24, 2005, 20:04
zxaar
yes i always do so, as a general practice i make mesh in parts , merge them ..then read them in fluent ... then fuse the zones ... then save them as cas file ..and import it in gambit. it makes a nice single mesh ..i usually use this mesh for analysis
Old   February 24, 2005, 20:05
zxaar
in gambit ..use import mesh, fluent5/6 ... select 3d mesh and then just import it
Old   February 25, 2005, 04:33
Y
Thanks its working fine. Actually I have another problem I made grading of my mesh and exported it to mesh file And then I forget about what value or what type of grading I used when I imported this mesh file back in gambit to check then grading which I used. I could not see the value in fact I see the default option. How can I check what value and what type of grading I used. Y
