Flow around Two Tandem Cylinders
Old   February 22, 2005, 00:11
Default Flow around Two Tandem Cylinders
Atef
Hi everyone, I am trying to simulate the flow around two tandem cylinders (one cylinder is in the wake of the other) at a Reynolds number of 20000. Dose anyone know which turbulent model will work better? I used the DES, but I got very strange flow structure in the gap between the cylinders and Strouhal number was higher than that reported in the experimental work. Thanks in advance. Atef
Old   February 22, 2005, 03:57
Default Re: Flow around Two Tandem Cylinders
Sham
I am modelling a similar situation and I use k-e RNG Model and it seems to work OK with mine.
If you are interested we can work together to improve our model and just give me an e mail.
Sham.
Old   February 22, 2005, 15:30
Atef
Thanks Sham for your response. I look forward to working with you in this simulation.
Atef
Old   February 24, 2015, 12:35
Oghenemaro Benedict Egweni
megweni is on a distinguished road
hey guys, I would be interested to work with you on the analysis of tandem cylinders in CFD. please email me on megweni@yahoo.com if you can
megweni is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
PROBLEMS WITH ROTATING FLOW BETWEEN TWO CYLINDERS vitmalin CFX 2 October 11, 2006 08:22
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Help: Poiseulle flow benchmariking Mohammad Kermani Main CFD Forum 1 November 12, 1999 17:15
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
