Droplet Generation
Old   February 21, 2005, 11:05
Default Droplet Generation
nic
Hi
Just wonderin if any1 has a step by step method for introducing immiscable oil droplets into a fluid flow.
Thanx,
Nic
Old   February 22, 2005, 13:45
Default Re: Droplet Generation
amir
Hi Nic i have similar problem. perhaps using multiphases flow modeling (vof)is a good idea . regards amir
Old   February 23, 2005, 15:45
Spyros
Hi
First you need tou enable VOF model.remember to initialize at the beginning. Then you need to specify the 2 phases you have. Make sure you have both materials in the material panel. After that you need to go Adapt-->region. You will specify the dimmensions of the droplet and the position inside the domain and then you will click mark. After that you will go to initialize--->patch. You will see in the panel down and left a new zone click on this zone and then patch the second phase.
Good luck
Droplet Generation Isahi Patil Main CFD Forum 0 August 4, 2006 06:11
Droplet Generation nic Main CFD Forum 1 February 22, 2005 13:51
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 01:48
Latest new in mesh generation Robert Schneiders Main CFD Forum 0 February 16, 2000 08:12
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 05:07
