Gambit batch - kill "Startup" box how?
Old   February 18, 2005, 14:17
Default Gambit batch - kill "Startup" box how?
Chris Bailey
I am running Gambit in batch mode from another program by passing a command line argument to the OS (Windows). I instruct Gambit to read a journal file, which ends with "abort force" to exit Gambit. It works, but after Gambit closes the "Gambit Startup" box is still there, waiting for me to click on "Close". Therefore the other program is still waiting for the command to finish executing, and there they sit forever. I can't tell the other program to click on the little "Close" button every time it comes up (can I?). How do I get Gambit to make its closure complete by taking the Startup box with it as it closes?
Old   February 19, 2005, 13:11
Default Re: Gambit batch - kill "Startup" box how?
An Modh Coinniolach
I had a problem like this. I eventually wrote a program to kill the Gambit process if Fluent had not been started after a reasonable amount of time.
Old   February 23, 2005, 10:05
Default The fix - critical patch 1
Chris Bailey
I found out this is a problem with Gambit, and it's fixed by downloading and applying "critical patch 1" from the Fluent site. Seems to work fine now.
GAMBIT Batch Mode - MATLAB asd Main CFD Forum 12 October 1, 2018 09:12
mesh rectangular box with 0.1mm diameter holes in gambit sohi FLUENT 0 April 23, 2011 03:47
Gambit batch mode query Krish ANSYS Meshing & Geometry 0 April 14, 2010 09:49
cleaning gambit journal file in batch mode HK FLUENT 0 April 1, 2008 21:35
Running Gambit as a batch job Narayan FLUENT 3 March 23, 2000 10:56
