conjugate heat transfer?
Old   February 17, 2005, 08:59
Default conjugate heat transfer?
Tim
Hi,All
Whether the conjugate heat transfer can be modeled in Fluent? One more question, sources can be added on the wall or solid-fluid interface? Thank for help, Tim
Old   February 17, 2005, 12:25
Default Re: conjugate heat transfer?
Doru Grosan
You must have in your geometry a two-sided wall. When Fluent read this kind of geometry in the thermal conditions you will have a conjugate heat transfer condition.You can specify a heat generation rate, but may be in your problem you will have to write an UDF for this.
See: Fluent User Guide Cap.6, pp 6-65.
Old   February 18, 2005, 00:09
Tim
Thank you, Doru Grosan
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 16:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
